Is there a way to control Thresholds at the operation level with the Soap decode
bcox2
Organizer
I am trying to set Thresholds for specific operations, but in the Soap decode Software services I only see threshold at the SS level. I know you can go to a lower level with HTTP.
If this is a limitation currently is it fixed in 12.4.5 decode changes?
Brian
Hi Brian
This functionality has been added but only to the new High Speed AMD architecture. If you wish to set individual thresholds then you need to migrate to the HS architecture. There is no plan to add this functionality to the classic AMD architecture.
There is currently an Expert Services offer to help customers migrate from the classic AMD to the HS AMD. If you would like more information on this service please reach out to your account manager or CSM.
Regards
Alasdair
bcox2
Organizer
Ok thanks. We are getting ready to start testing the new HS AMD functionality, so I will add this to our list to verify.
