Is there a way to rename miscellaneous parameters?
ruth_lehane
Contributor
They are automatically named miscellaneous parameter 1, miscellaneous parameter 2 etc. Is there a way to rename these for the purpose of showing them in DMIs?
3 REPLIES 3
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Ruth,
You can column alias names in the Result Display tab when you are editing the section, as shown below
Was just going to suggest this lol.
Thank you Harshal 🙂
