LDAP monitoring question
wim_desmecht
Organizer
At Colruyt we are using the ldap decode of dcrum for some time now. In order to increase the level of monitoring we do for LDAP there are some questions to be resolved:
1) when there is an error, we want to see the request details of the ldap query that caused the error. How to achieve this?
2) in our environment we use Kerberos AES. Is it possible to decrypt this traffic in the AMD?
3) can
dcrum decrypt Traffic from Keberos
AES which is again encrypted with a SSL Certificate?
Thx,
Wim.
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
What AMD do you use, Classic or HS?
wim_desmecht
Organizer
Classic AMD.
