Manually set link speed for router
cosmin_gherghel
Dynatrace Pro
Dynatrace Pro
Is there a way to manually set the link speed for a interface? Scenario is this:
I have an AMD in the cloud getting netflow from several routers and interfaces. SNMP polling is not available to get ifindex name or link speed. Is there a way to manually set the link speed for an interface exporting netflow?
matthew_eisengr
Inactive
Yes, I believe you set this in the link alias XML file.
Is this possible to set in the link_groups.xml ? It was not document and what's the attribute name to use in the link_groups,xml to set the link speed ?
