Masking Sensitive info in DCRUM V12.0.1
george_bouriako
Inactive
Question from the field:
"...I remember that DCRUM can mask sensitive information with ‘xxxx’ in DCRUM in previous versions, but I didn’t find the configuration tab in v12.0, are you aware anything of this please?..."
Answer from documentation:
  • Please go to 12.0.1 documentation at Frontline:
http://frontline.compuware.com/Doc/A8/A81201/PDF/RUMDC_WebAppMonitoringUserGuide.pdf
  • Search for "sensitive"
  • Go to page 149 for detailed explanation
  • The requested config is under "Entire Config ? Devices ? Open Config ? Edit as Draft" and further:
    • Global ? Front-End Monitoring ? Web ? HTTP ? Transactions and Header Data ? General
Thank you.
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Latest doc for HTTP and SQL.
