Monitoring SNMP Traps with DCRUM
Hello all,
Didn't found such information in the documentation.
It is possible to monitor SNMP Trap communication between some network devices and server? They are interchanging informations using SNMP Traps.
I Tried Generic analyzer, UDP analyzer, but i don't see anything in CAS. What analyzer should i use?
chris_v
Dynatrace Pro
Dynatrace Pro
DC RUM doesn't decode SNMP (or traps), you won't get anything more than the basic bytes/packets type info.
Also you may have the client/server relationship wrong, and are using the wrong IP in the software service for the traps. Are you defining the 'server' or the 'network device' in the software service, you may have to swap.
