MozillaBrowser won't work at all
igor_simoes1
Inactive
I am developing a script on Agent Recorder and MozillaBrowser won't work at all. Everytime the script comes to the following line I receive an error:
Set mb = MozillaBrowser("Caption='Carrefour Soluções Financeiras'")
I have also tried using the following options with no luck:
Set mb = MozillaBrowser("")
Set mb = MozillaBrowser("FireFox MainWindow")
Could someone please help me understand what should I do in order to have this windows being propperly reconized? I need the mb variable so I can use WaitForSelctableText further down the script.
3 REPLIES 3
david_n
Inactive
Hello Igor,
It looks like you need "variable = object.MozillaBrowser" in order to have the Mozilla variable work.
https://community.dynatrace.com/community/display/ENTSYM125/MozillaBrowser+Method
David Nicholls
yuriy_look
Inactive
Hi Igor,
You are probably using a Firefox release not listed in the bottom table of https://community.dynatrace.com/community/display/PUBDCRUM/Supported+Browsers+in+DC+RUM. So, your choices are:
  1. Using one of the listed Firefox releases.
  2. Using Window instead of MozillaBrowser or MozillaWindow.
  3. Using Internet Explorer as a Web browser.
The first option is valid, of course, only in case your application
can run in these (somewhat outdated) versions of Firefox. Likewise, you
can use the third option only if your application can run in IE.
Thank you,
Yuriy
That was the case. Had to switch back to IE and scripts are now working fine.
Thanks a lot.
