Need help on creating a search form in DMI
tdavison2
Organizer
Hello everyone,
I am trying to figure out how to create a search form in DMI. I have some previously created DMI reports that were created by someone else that first starts with a search form where I can filter on Dimensions. I can't figure out how to activate a form on a newly created DMI report.
Thank you as always for any help,
Tom
john_leight
Dynatrace Pro
Dynatrace Pro
To display a report as a form, it must be saved as a form.
From the report definition, not in section editing, instead of saving the report display it as a form from the "..." menu in the upper-right. You can edit the fields to be displayed on the form from there. When you are done editing, save the report while the form is displayed.
The next time the report is opened the form should be displayed.
tdavison2
Organizer
Thank you very much for your help John. I couldn't find it too save my life. Have a good day.
Tom
