POST parameter capture DCRUM2017
Shirai
Guide
Hello
In the environment of DCRUM 2017 SP 6, we are testing to obtain the POST parameter of the WEB site. I am thinking that it is defined on "Rule editing" "dimension, metrics, attributes" tab of software service of RUM console, but I am testing, but I can not get POST parameter correctly with DCRUM.
I am trying to access the demonstration site "easytravel" built in the internal environment and obtain the POST parameter with DCRUM. I am sorry on the Japanese display screen. I will attach a screenshot of the definition. Please give me advice.
3 REPLIES 3
nkobayashi1
Helper
POST
parameter exists in the Request Body. So I
think that you should set Request Body to the Choose "Where to search for the value" section.
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello @Toshimasa S.
Have a look on the below link for searching / configuring within the payload.
https://www.dynatrace.com/support/doc/nam/rum-cons...
Babar
Shirai
Guide
Hi.
I was able to get the POST parameter. Please see the attached setting. I thank for the advice.
