Problem finding xml/soap operations
ckc
Organizer
I have a problem finding operations using the XML over http analyzer
When I go in the wizard and choose the traffic trace I made on the two servers which the software is setup to, I can see 1435 operations with the soap analyzer, when choosing the XML I see one! Problem is the messages are not soap standard so its not soap analyzer capable so I need to use the XML.
Before we upgraded to 12,3,1,15 it worked find, seems something in the upgrade have done something but not 100% sure it got something to do with this since we migrated the platform to new supplier aswell
Any ideas on how I can go about this, when only soap analyzer catches the operations but since not standard have to use the XML analyzer?
Claus
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
First of all try if turning off _Validate SOAP/XML document before parsing_ option both in SOAP and XML would change anything ...
ckc
Organizer
superb, working now
Could see on the AMD on the old supplier this was not enabled, unchecked it on the new AMD´s and working now, thanks for the help
