Problem with resolution/time range
ckc
Organizer
We seem to have a issue with resolution/time range and aggregated data.
When I make a report for over a month we can not choose resolution larger then 6 hours, when I choose 1 day we get:
Our storage period configuration is set as:
Any ideas why this is?
Claus
9 REPLIES 9
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Claus,
Not all metrics and dimensions are aggregated, i.e. unique users, affected users and performance metrics related to affected users.
Can you share screenshot of the report definition: dimensions and metrics?
ckc
Organizer
Dimensions:
Metrics:
I got Unique users in metric so they are never aggregated?
Correct you can have it only as long as AMD_STORAGE_PERIOD is set.
Let me find out if Enabling User Activity Details and Server Statistics on Demand can help and get back to you.
Still testing this stay tuned.
Hi Adam,
Any good news with the testing (smile)
Claus
Hi Adam,
Any good news regarding your testing.
Claus
ckc
Organizer
Hi Adam,
Did you find out it Enabling User Activity Details and Server Statistics on Demand, I read through it several times and dont see any solution there.
Claus
Claus,
I meant Enable access to user activity details and server statistics on demand part of this manual.
ckc
Organizer
So if I enable this then it will store users in that file and im able to use this in DMI?
