Publishing issue
cwilmoth
Newcomer
We are trying to change an operation threshold value in RUM console and publish it to the AMD. The value is changed, but after publishing to the AMD and rerunning a report that shows the operation threshold value, it is still the same. We have changed it and published multiple times and it never changes. Any insight?
Thanks.
cwilmoth
Newcomer
Sorry - version 12.2.0.465 of CAS and 12.2.0.333 RUM Console...
Radoslaw_Szulgo
Dynatrace Guru
Dynatrace Guru
What do you mean by "Operation threshold" ?  Operation load time threshold ? Operation time threshold?  Something different ? Note, that usually such settings are provided to the CAS via data samples, so you need to wait until new data sample is processed on CAS. Then, see the report for the time when new setting was set.
Senior Product Manager,
Dynatrace Managed expert
