RTM connect issue
dave_huang
Inactive
I install AMD 12.4.x and set up the community port and capture port.
When I use command in "rcon" mode, it appear message that could not connect RTM.
grzegorz_sulest
Dynatrace Helper
Dynatrace Helper
Please verify if the rtmhs service is running with the following command:
service rtmhs status
If the service is not running you can browse the rtmhs.log for more details:
tail -f /usr/adlex/log/rtmhs.log
If the indication given in the log is not clear enough you should consider opening a support ticket.
Note: DC RUM and ESM release 12.4 is no longer supported, effective July 1, 2018
