RUM console configuration issue
dave_huang
Inactive
Hi all,
I do a test that upgrade DC-RUM from 12.4.x to 2017SP5.
I set the configuration to connect ADS、CAS、AMD on RUM console.
But for the AMD it appear a message that the version doesn't match(or unknown)
I didn't import the license ,it just for a migration test.
Does it just causes because of the different 17.0.5.34 and 17.0.5.50 ?
Please refer to the attached file.
B.R
Dave
3 REPLIES 3
Babar_Qayyum
Leader
Hello @Huang D.
What is the Classic AMD version?
Have a look on the below link for the DC RUM 2017 integrated components compatibility:
https://www.dynatrace.com/support/doc/dcrum/upgrad...
Babar
Hi @Babar Q.
Is this the classic version?Please refer to the attached "3.png".
I have another question that what is "Authentication" account in attached "4.png?
Is it RUM console account?
Hello @Huang D.
In the 1.png shared by you the classic is mentioned for the AMD.
The default credentials are adlex/vantage for 2017 AMD to configure in the Console.
Babar
