Recording Microstrategy Web applications
michel_schuster
Inactive
I'm not able to record clicks within a Microstrategy application.
Issue can be easily reproduced using the Microstrategy demo site:
https://demo.microstrategy.com
Here is my code:
Sub Main()
Taskbar("Index=1").Attach
Taskbar.Select "Google
Chrome"
Window("Application=chrome.exe
Caption='Nouvel onglet - Google Chrome'").Attach
Window.Size 1004, 708
Window.Move 13, 12
Window.Type "https://demo.microstrategy.com{Entree}"
Caption='Tutorial Home. MicroStrategy - Google Chrome'").Attach
GUIObject("ClassName=Chrome_RenderWidgetHostHWND Caption='Chrome Legacy
Window'").Click 702, 522
Caption='Reports. MicroStrategy - Google Chrome'").Attach
Window'").Click 703, 482
Caption='Subtotals. MicroStrategy - Google Chrome'").Attach
Window("Application=chrome.exe Caption='Subtotals. MicroStrategy - Google
Chrome'").Click 119, 35
Caption='Chrome Legacy Window'").Click 24, 16
GUIObject("ClassName=Chrome_RenderWidgetHostHWND Caption='Chrome Legacy Window'").Click
588, 514
Caption='Dashboards. MicroStrategy - Google Chrome'").Attach
Window'").Click 584, 452
End Sub
It doesn't playback the click on 'Report'.
Any ideas ?
yuriy_look
Inactive
@Michel S.
Hi Michael,
I cannot give you a specific
advice regarding clicking on report, because your script is not portable across
multiple agents. To make it portable,
you need to
1. Standardize on screen resolution,
which would mean that if you expect other people to run your script, they
should know what screen resolution they should have.
2.Maximize any frame window* once it is
created, before scripting any actions against it.
For the second requirement you may replace
Window.Move 13, 12
with
Window.Maximize
Since your script is based strictly on coordinates, now you will
need to put a break point on the line right below the newly created line and
re-record the rest of your script.
Now, as I understand, some, or
possibly all, clicks on GUIObject("ClassName=Chrome_RenderWidgetHostHWND
Caption='Chrome Legacy Window'") did not work for you. If you read the release notes, you’d notice
that working with inner objects in Chrome is not supported. So, we’ll need to edit the script further. First, we need to find out relation between
the frame window Window("Application=chrome.exe
…") and GUIObject("ClassName=Chrome_RenderWidgetHostHWND
Caption='Chrome Legacy Window'"). You will need to use the identify tool. On my machine GUIObject…
occupies the whole width of the maximized frame window, but does not a strip on
the top of it 74 pixels high. (look at Left and Top properties of the control). Now we can combine recorded lines to reference the frame window. Say,
Window("Application=chrome.exe Caption='Tutorial Home. MicroStrategy - Google Chrome'").Attach
GUIObject("ClassName=Chrome_RenderWidgetHostHWND Caption='Chrome Legacy Window'").Click 740, 545
should be replaced with
Caption='Tutorial Home. MicroStrategy - Google Chrome'").Click 740, 619
(740+0=740;
545+74= 619)
Hopefully once you’ve done all
of this your script will play back OK. With all this said, you’ve probably realized that recording is only one
of the tools you can use for script creation. Should you have more questions about scripting, please try to find the
answers in the documentation and in this Forum. If you cannot find the answers, place your questions in this Forum
discussion or create new ones, as appropriate.
Thank you,
Yuriy
* If you need clarification on this term, please see https://msdn.microsoft.com/en-us/library/5c2fsa5a.aspx
and https://msdn.microsoft.com/en-us/library/windows/desktop/dn742501%28v=vs.85%29.aspx.
