Registered applications and dashboards disappeared
rfigueiredo
Inactive
Hello, I have a CAS Server 12.2.4 installed with two AMDs reporting to it. It was all working normally, I just pointed the CAS to use another Database but I did the whole process of migrating to a new database keeping the same data and everything was working. But after a few weeks my configured applications and reports are gone, it's as if CAS has nothing configured.
But when I look at the logs and Rum Console, there's nothing wrong with the status. Softwares services were not affected, they remained, but applications no longer appear.
Anyone have any tips?
This sounds like a issue that can only be resolved Quickly by opening support ticket, and you should even totally do that if the database migration happened just not long ago.
