Relationship Between Operation and Component
From
what I understand, typically when a page load, it would first fetch the main
page (xhtml,
jsp,
aspx
etc.) then only subsequently fetch all the resources like css,
jpg, png,
favicon, js
and so on.
So
in this typical scenario, normally the first fetching of the web page would be
‘operation’, and the subsequent resources fetching would be ‘component’ is that
correct?
My
question is: If that is correct, then why would the operation columns sometimes
showing a dash instead of the URL name?
If
that is wrong, please correct me on any of my misunderstanding
ulf_thornander3
Inactive
Well - it can be a number of things but one that comes to mind is packet drop.
If you loose 1 packet, that operation might not be decoded, but the subsequent requests will.
