SOAP Methods not mapping in DCRUM 2017
Hello everyone,
After upgrading from 12.3 to 2017, one of the software service changed from SOAP over HTTP to HTTP , which I understand, as both XML and SOAP were merged into HTTP protocol. But in the operations we are no only seeing the SOAP method calls only http calls. I also added 'application/soap+xml' to the content-type of the software service.
Any suggestions?
3 REPLIES 3
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Look at this ticket about the impact of the XML decode migration.
I hope it will help you.
https://support.dynatrace.com/supportportal/browse...
In my case, the SAOP software service didn't decode correctly with the migrated configuration. I recreated all my SOAP software service with the recommanded configuration (as describe by the support) and after that the issue was fixed.
JLL
I have received feedback from @Adam P.. In 2017, SOAP methods are mapped to Miscellaneous Parameter 5. The operation will show the http uri called, with the Miscellaneous Parameter 5 showing the SOAP method invoked. Adding this dimension to the DMI should allow you to see the SOAP method.
Thanks @Adam P.
That's good to know. Thanks Jose for sharing this valuable information.
