Setting health index threshold for a particular application (DCRUM)
elvin_yeo
Contributor
May I know if we can set a custom health index threshold just for one particular application.
I have an application which I do not want the health index threshold to be based on the global setting.
Thank you.
3 REPLIES 3
BabarQayyum
Leader
Hello Elvin,
The easiest way is to make the copy of AHS report and then modify the thresholds as per your need and then add the application.
Babar
elvin_yeo
Contributor
@Babar Q. thanks for the warm reply. Seems like it will be inconvenient if i create a copy of AHS report
Hello Elvin,
Just save with the different name and its done.
Babar
