Synthetic Agent dimension for Enterprise Synthetic and sequence transactions alerts
Janusz_Blank
Dynatracer
Dynatracer
Since release
12.4 the RUM Console ships with a new “Synthetic Agent” monitoring dimension for
“Enterprise Synthetic and sequence transactions” alerts. This new dimension
introduced a number of restrictions on the alert configuration, which I’d like
to discuss here along with other restrictions which were already present and
may sometimes lead to confusion.
General restrictions
1. Comparison mode is always “Single”
for this type of alert since 12.4
2. Baseline source is always “Average
baseline” for this type of alert since 12.4
3. Monitoring time range is by default
set to “last monitoring interval”, which is configured on CAS and is by default
5 minutes. In order to select a different monitoring time range, a user has to
select “Transactions (Enterprise Synthetic)” as Transaction source.
4. When Transaction dimension is
selected as monitored dimension without Application dimension, than threshold set
on any “user counter” metric is not available.
User counter metrics for this alert type are in fact just one metric “Unique
users”. This restriction holds only if “Transactions (RUM)” is selected as
Transaction source dimension filter value.
5. Synthetic agent dimension and filter
are not available for alerts tracking sequential transactions, that is those
with “Transactions (RUM)” selected as Transaction source. Also, the Monitoring
time range is always equal to a sampling interval (has a value of “last
monitoring time range”)
Baseline
restrictions
1. For alerts tracking synthetic
transactions (those with “Transactions (Enterprise Synthetic)” selected as
Transaction source), a baseline threshold can’t be defined if Synthetic Agent
dimension is selected.
However any combination of monitored dimensions except Synthetic Agent is
available along with the baseline threshold in such case.
2. For alerts tracking sequential
transactions, a baseline threshold is available for the following combinations
of dimensions:
  • Application
  • Transaction
  • Application and Transaction
  • Region
  • Area
  • Site
  • Application and Region or Area or Site
  • Transaction and Region or Area or Site
3. A baseline threshold is unavailable if a
non-default filter value is set for a dimension filter, which corresponding dimension
isn’t selected as monitored dimension.
3 REPLIES 3
raffaele_talari
Inactive
Thanks for sharing your knowledge, Janusz! Good article, I believe it'll be very helpful to lot of us!
Ciao, Raffaele
Good article to clarify lots of mystery. Thanks Janusz.
I have a question about the email alert time range that need your advise. In my scenario, I have a ESM transaction running every 30 minutes, CAS alert "monitoring time range" set to "15 minutes" and "
Transactions (Enterprise Synthetic)”.
There was an transaction failed at 15:02pm. I received the first alert at 15:11pm, when I click the report link it shows report from 15:05pm to 15:10pm which was empty. Then I received another alert at 15:16pm, the report link shows 15:10pm to 15:15pm which was empty again because the transaction failed only failed at 15:02pm. Two questions need help here:
1. Why the email alert re-generated at 15:16pm?
2. How to make the report link shows the correct time frame which covers the time when transaction failed? 12.3 works well.
Any comment are appreciated.
Thx
Sylvian
roman_rycaj
Helper
General restriction no 4 does not apply to an alarm for which Transaction Source has been specified with Transactions (Enterprise Synthetic).
