Synthetic Enterprise Metrics within a DCRUM custom metric.
lucas_mitraud1
Inactive
Hi everybody!
A customer needs to see the server time + network time, (ignoring the client time since they are robots...) on a EP dashboard.
I've tried to convince the customer that the client time is important, but he is really stubborn...and asked for this "custom metric".
That said, I would like to know if it is possible to configure a DCRUM custom metric based on Synthetic Enterprise metrics?
If so, can anyone share the procedure?
Thanks in advance
4 REPLIES 4
ulf_thorn222
Inactive
Have you checked around in the DMI?
What version are you on?
Hi Ulf,
The whole environment is currently on 12.2.
I've located the metrics server time, network time and client time on the DMI, and I would like to join the Server and Network time in one custom metric and use it to generate performance alerts...
I did not found any info about this metrics "fusion".
jaroslaw_orlows
Dynatrace Pro
Dynatrace Pro
Lucas, I'm not sure if it's exactly what you're looking for, but the DC RUM alerting system has a functionality called "Compound metric". See Configuring Trigger Conditions for Alerts for details.
Here's a screenshot taken from the definition based on Synthetic and Sequence alert type, using a compound metric based on a sum of server and network time.
Best regards,
Jarek Orlowski
Information Developer
sid_govindu
Dynatrace Organizer
Dynatrace Organizer
Lucas,
You can define a custom metric that performs arithmetic on pre-defined metrics.
User-Defined Metrics in DMI Data Views
Sid
