Synthetic Monitoring Siebel-Oracle with Recorder (testPartner)
ccarrasco
Inactive
Mrs,
What is the best way for monitoring Siebel - Oracle with syntethic recorder?
whenever monitoring SIEBEL, I have trouble capturing events or recognize objects. There a way to integrate with Siebel Recorder?
thanks.
Carlos
david_alonso
Dynatrace Pro
Dynatrace Pro
the testparner generates Visual Basic code. If you are able to use on the siebel recorder to integrate the event library calls probably using it. I don't know if this is possible on the "Siebel Recorder".
Anyway you can bypass this object identification with visual test. We've been using it on Citrix with good resutls. Of course you need that the OS configuration is the same in the development agent and in the agents where you are going to deploy. When you get the object recognition problems is a good alternative.
