TCP Decode only, will auto discovery still work?
cosmin_gherghel
Dynatrace Pro
Dynatrace Pro
If I have an AMD that is only licensed with the TCP decode and auto discovery is turned on will the CAS still show auto discovered software services?
alasdair_patton
Dynatrace Pro
Dynatrace Pro
Hi Cosmin
As far as i am aware it should. I seem to recall a discussion with product management where they said it will try and use decodes where licensed but will revert to generic for things that aren't. As some of the AD ones are set to use decodes.
If that doesn't work you could always just change the analyzers for each AD software service.
@Kris Z. can you confirm?
Regards
Alasdair
