Trying to Create UDG using Server IP as Point and does not seem to work
bcox2
Organizer
Can anyone tell me if there is a trick to get Server Ip's to work as points on the UDG reports? I have done them with application and software service as points just fine. Is this a limitation of the report, or am I missing something.
Brian
4 REPLIES 4
brett_b2
Inactive
Hey Brian,
I tested this in my home lab and Server IP seemed to work fine. Can you share your DMI settings?
Here is how I have it sent up. I am running 12.4.2
Hmm, that is strange. I can see you've set Server IP as a point, correctly, but your UDI appears to use Time as a dimension, which actually isn't possible as a point (at least it wasn't in 12.3). I'm not sure what's going on. You can raise a support ticket or we could look at it in a quick webex.
cosmin_gherghel
Dynatrace Pro
Dynatrace Pro
Hi Brian,
Under your selected dimensions is Server IP set as a Point or Filter?
-Cosmin
