URL Monitoring - Regular Expression
skung
Organizer
DCRUM report url with session information currently for example: https://ics-cdw-prod.allstate.com/icscdw/(s(1pcegccicl0weu3mynyurbrn))/contentpages/extendedview.asp...
Can you suggest regular expression I can use to define in URL Monitoring to only report url like https://ics-cdw-prod.allstate.com/icscdw/contentpages/extendedview.aspx
Thank you
Sharyl
7 REPLIES 7
alasdair_patton
Dynatrace Pro
Dynatrace Pro
Hi Sharyl
This should do it for you (https://ics-cdw-prod.allstate.com/icscdw/)[^/]+/(contentpages/extendedview.aspx)
This assumes you are using one of the latest versions of DC-RUM that uses extended regex.
Regards
Alasdair
skung
Organizer
Do I have to specify the rule for every url? All pages have same pattern for example another page looks like this https://ics-prod-cdw.allstate.com/icscdw/(s(xnszawb1cxkdcpfzsighphv5))/contentpages/search.aspx and I would like to report to https://ics-prod-cdw.allstate.com/icscdw/contentpages/search.aspx
alasdair_patton
Dynatrace Pro
Dynatrace Pro
No the one I gave you would specifically have to end with contentpages/extendedview.aspx
If you want one that would cover all scenarios replace the second part with .*
(https://ics-cdw-prod.allstate.com/icscdw/)[^/]+/(.*)
However with this you will only be able to set one operation threshold to cover all. If you need different thresholds for each then you will have to do them separately.
Regards
Alasdair
skung
Organizer
It is not working. Shouldn't this part "[^/]" to be modified? as everything between the two "/" has to be ignored
alasdair_patton
Dynatrace Pro
Dynatrace Pro
Which version are you using?
12.2.2.74
Alasdair,
I tested the one again you suggested earlier. It is working. Thank you very much.
Sharyl
