Url Monitoring with Static Frame
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Experience with static frame
This option is useful when the automatic frame consolidation doesn’t work, and each component is collected by DCRUM as a complete operation.
 In this case, there are a lot of operations with only 1 hit by operation and the operation time is very optimistic
(image 1 : URL monitoring without static Frame)
After configuring the static frame, the page is complete with 8 hits
(image 2 : URL monitoring with static Frame )
Configuration of the static frame
The operation starts for each URL Monitoring,
all the other components are attached to the operation
              the operation is finished if
  • The time between 2 components is more than 3 seconds (default parameter of the hit session  timeout)
  • Or if the following component is an operation configured in the URL Monitoring.
Example of URL Monitoring list with static frame option configured:
!! Don’t apply any global configuration in the URL Monitoring like: (http://.*) - it disable the static frame configuration for all the other URL monitoring…
Limit of the static frame option
It’s working better when the operation starts with the same component, and if the « entry point » component is not a component inside an operation too.
If a component is an entry point component of the operation and is also a component inside the operation, there will be 2 operations instead of 1 operation.
3 REPLIES 3
ulf_thorn222
Inactive
Very nice write up JLL!
david_alonso
Dynatrace Pro
Dynatrace Pro
great!
david_lopes222
Inactive
Thanks for this!
