Username recognition : regex for character replacement
antoine_buffoto
Dynatrace Helper
Dynatrace Helper
I wanted to know if in the RUM Console, defining the username recognition, is it possible to replace a specific character by an other ?
In my case, the parameter is known, and we want to replace the "+" character by the " " (space) character.
Thank you for your answer.
Regards, Antoine
wojciech_kurek
Inactive
Antoine,
No, character substitution in AMD configuration regexes is not possible.
Wojtek.
chris_v
Dynatrace Pro
Dynatrace Pro
How are you extracting the name?
There are 'transformations' you can add to the results of a regex to decode various common encodings, base64, gzip compression, and what you want here, 'url encoding'.
