Using regular expressions window's name
apineirogayo
Newcomer
I would like to know if we can use regutar expression working with name's window. For example:
JavaWindow("Application=JP2LAUNCHER.EXE Caption='Workbench PROD-Umgebung 4.6'").Attach
We would like to avoid re-write the script if new version comes (4.7, 4.8,...):
JavaWindow("Application=JP2LAUNCHER.EXE Caption='Workbench PROD-Umgebung*'").Attach
Thank you!
Best regards
yuriy_look
Inactive
@Antón G.
Hi Antón,
The Recorder does not support regular expression character string matching,
but it does support wildcard character string matching, which means that the
expression you’ve put as an example will work. You may want to take a look at https://community.dynatrace.com/community/display/ENTSYM125/Using+Variables+in+Test+Scripts
and https://community.dynatrace.com/community/display/ENTSYM125/Agent+Recorder+FAQs
and search for the word wildcard on these pages.
Thank you,
Yuriy
Hi, thank you so much!
