Where should TCAM be installed for monitoring XenApp?
Carl_Morphet
Dynatrace Mentor
Dynatrace Mentor
Which component should the TCAM be installed for monitoring a Citrix XenApp deployment?
  • StoreFront
  • Delivery Controller
  • Studio
  • Directory/License
  • Resource Servers
Kind Regards,
Carl
chris_v
Dynatrace Pro
Dynatrace Pro
I'm not familiar with those terms, but the Presentation Server is the correct answer.
i.e. where the users applications are running.
Carl_Morphet
Dynatrace Mentor
Dynatrace Mentor
Hello Chris, thank you for the response it was what Citrix called the Resource Servers in this case,
@pieter.van.heck@dynatrace.com kindly walked through it, from that I developed the attached presentation dc-rum-citrix-monitoring-examples.pdf
