cba-agent not starting correctly after upgrade
henk_stobbe
Mentor
11 REPLIES 11
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Can we take a look at cba-agent.log?
For java version I am save:
=== The default Java machinejava version "1.7.0_55"
Java(TM) SE Runtime Environment (build 1.7.0_55-b13)
Java HotSpot(TM) 64-Bit Server VM (build 24.55-b03, mixed mode)=== Installed Java packages
java-1.8.0-openjdk-1.8.0.65-0.b17.el6_7.x86_64
java-1.8.0-openjdk-headless-1.8.0.71-1.b15.el6_7.x86_64
java-1.7.0-oracle-1.7.0.55-1jpp.1.el6_5.x86_64
The cba-agent is running, but I do not see the external port on my system, so console can not connect to guided configuration.
@Adam:
no errors in logfile but in the cba-osgi.log:
!ENTRY org.eclipse.osgi 4 0 2016-02-04 18:22:25.636
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.jms.clients_12.4.0.69.jar was not resolved.
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.jms.config_12.4.0.69.jar was not resolved.
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.jms.config.impl_12.4.0.69.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2016-02-04 18:22:25.637
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.jms.diagnostics_12.4.0.69.jar was not resolved.
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.osgi.management_12.4.0.69.jar was not resolved.
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.statsdata_12.4.0.69.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2016-02-04 18:22:25.638
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.statsdata.impl_12.4.0.69.jar was not resolved.
!MESSAGE Bundle initial@reference:file:com.compuware.configuration.agent.utils_12.4.0.69.jar was not resolved.
OK, then what is the output of:
netstat -plnt
command?
[root@bamcyb1-mon01 ~]# netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 2250/sshd
tcp 0 0 127.0.0.1:31415 0.0.0.0:* LISTEN 10901/rtm
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 2334/master
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 14117/stunnel
tcp 0 0 0.0.0.0:8006 0.0.0.0:* LISTEN 11524/mono
tcp 0 0 0.0.0.0:6 0.0.0.0:* LISTEN 2348/garudad
tcp 0 0 127.0.0.1:199 0.0.0.0:* LISTEN 10942/snmpd
tcp 0 0 :::22 :::* LISTEN 2250/sshd
tcp 0 0 ::1:25 :::* LISTEN 2334/master
tcp 0 0 ::ffff:127.0.0.1:9091 :::* LISTEN 14204/java
tcp 0 0 :::8009 :::* LISTEN 14204/java
There should be java process listening on 0.0.0.0:9094.
Please attach cba.log and cba-agent.log.
If you cannot attach it here please open support ticket.
We found that after upgrading to 12.3.x that the java versions we had on our AMD's wasn't sufficient for CBA, causing it not to work. I believe you need at least Java version 1.7.0
From a conversation with Dev on this topic, the supported java versions for the CBA Agent are
java-1.6.0-sun
java-1.7.0-oracle
java-1.7.0-openjdk
-- Erik
henk_stobbe
Mentor
[root@bamcyb1-mon01 log]# cat cba-agent.log | more
2016-02-04 21:45:30,479 INFO [Activator] Registering Driver Extensions...
2016-02-04 21:45:30,483 INFO [Activator] ...registering driver: oracle.jdbc.OracleDriver
2016-02-04 21:45:30,513 INFO [Activator] ...registering driver: oracle.jdbc.driver.OracleDriver
2016-02-04 21:45:30,725 INFO [ContextLoaderListener] Starting [org.springframework.osgi.extender] bundle v.[1.2.1]
2016-02-04 21:45:30,790 INFO [ExtenderConfiguration] No custom extender configuration detected; using defaults...
2016-02-04 21:45:30,798 INFO [TimerTaskExecutor] Initializing Timer
henk_stobbe
Mentor
cba.log attached
wojciech_kurek
Inactive
Henk,
12.4 requires java 1.8 to be installed and set as default. You have java-1.8.0-openjdk installed, but it's not the default java instance. Please change it using the following command:
alternatives --config java
This should have been done automatically during the upgrade. Could you share your upgrade.bin.log file?
Wojtek.
Wojtek,
Solved thx.
No need to look at upgrade.bin.log. I have installed the 1.8.0 version with --no-deps. It was not functioning during install.)-;
After that I installed complete 1.8.0, but that was to late for AMD, my mistake.
KR Henk
