cba process not starting
henk_stobbe
Mentor
My cba process refuses to start, looking in the log is shows me that the "Application recognition component" failes to init. It seems there are errors in the packetmatchconfig.xml file.
"group is not allowed for content model", removing the record gives me the next in line.
1) can I fix this? Can I replace file back to default
2) how can this happen, has this to do with an 12.2
KR Henk Stobbe
Atos Groningen
10 REPLIES 10
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Have you edited the file manually or reverted it from other machine?
henk_stobbe
Mentor
No sorry, the file was not touched, attached peace of logging. I noticed in console cba-agent not talking to cba,
 bam_cba.txt
If you haven't touched it I would recommend opening support ticket ...
henk_stobbe
Mentor
It is an empty environment,, is it a big issue to replace the file with the default one?
Ahh, no problem, just give me exact build number of the AMD, either from ndstat command or /usr/adlex/config/applications.xml file.
henk_stobbe
Mentor
henk_stobbe
Mentor
12.3.1.31 (-;
henk_stobbe
Mentor
fyi, the "broken" file is identical  with the .before.upgrade one, the size is 30841, and I have a bck and a default one 50104 in size
Find attached default pktmatchconfig.xml for 12.3.1.31 build.
henk_stobbe
Mentor
Adam,
Sorry to keep you waiting, issue is solved,
Thx Henk
