change icon of speed dial dashboard
sylvian_lam1
Organizer
Hi All,
Is it possible to change the icon or ordering on the speed dial dashboard? Any doc describes that?
Thx
Sylvian
3 REPLIES 3
Karolina_Linda
Community Team
Community Team
Hi Sylvian,
According to the docs, you can't modify the Featured tab.
@Sebastian Kruk - can you confirm that?
Karolina
Keep calm and build Community!
It is possible to modify both icons on speed dial (per report and per section) and to change the set of featured reports - see config/dashboard-rtm.properties. However, those modifications are not officially supported and your changes may be overwritten by the upgrade.
Changing order is only possible in the Featured tab - see config/featured_reports.conf. Favorites are sorted alphabetically, and All reports are sorted alphabetically first by section name, then by report name within section.
Thanks Karolina and Sebastian. I won't modify the icon of build-in report but want to change my own DMI report. So is it possible to change the icon of my own DMI reports which put in the "Favorites" section?
-Sylvian
