data range for cas distribution chart
qianqian_peng
Inactive
i would like to create some distribution chart, e,g. RTT distribution. And i got the below link saying that we need to do some configuration in console:https://community.dynatrace.com/community/display/...
However, when i open my console, following the description in the above link, i got the message saying that this is not available for AMD version later than 12.4.0.
Anyone know other ways to create the distribution chart? I am currently using AMD 12.4.5.1842.
Clare.
alasdair_patton
Dynatrace Pro
Dynatrace Pro
Hi Clare
You are correct, distribution ranges have been removed from the product. You can achieve similar functionality by using the histogram feature providing you don't run your CAS in ISP mode.
Here is an example
and here is the config
For more information please refer to https://community.dynatrace.com/community/display/...
Hope this helps.
Regards
Alasdair
