difference of read and match keys
elvin_yeo
Contributor
hi guys, may i know what are the differences between read and match keys in the rcon "ssldecr keys" command?
Thanks !
wojciech_kurek
Inactive
Elvin,
A key marked as "read" is a key that has successfully been read (from the disk, or from decryption hardware), but has not been matched with any SSL traffic analyzed by the AMD. A key marked as "matched" has been read correctly and is being used to actually decrypt some traffic.
Wojtek.
