dimensionFilter Synthetic - 12.3 (custom) reports not changed after 12.4 migration
CAS 12.4 uses dimensionFilter "Enterprise Synthetic", where 12.3 uses dimensionFilter "Synthetic".
Existing CAS 12.3 reports (sections) that have dimensionFilter 'Synthetic', are not converted to the new
dimensionFilter.
This would mean all reports need to be adapted manually? Cumbersome, because some customers have a long list of such reports.
An export/import does not solve this either.
From Database:
SELECT TOP 1000 [row_id]
,[name]
,[created]
,[lastModified]
,[creator]
,[lastModifier]
,[reportServletPath]
,[httpMethod]
,[params]
,[version]
,[readOnly]
,[imported]
FROM [CAS].[dbo].[LSEntry] where params like '%>Synthetic</dimensionFilter>%'
I can run a SQL statement to do the update on the database. This would require also the CAS to be restarted. Perhaps there are other ways to accomplish this?
3 REPLIES 3
Karolina_Linda
Community Team
Community Team
Hi Frans,
In 12.4, we renamed "Synthetic" to "Enterprise Synthetic" to avoid confusion. We'll double-check the filter behavior after the upgrade and get back to you.
Karolina
Keep calm and build Community!
Thanks, Karolina.
Received response from support that, unfortunately, built-in reports were updated in 12.4, however there is no mechanism to upgrade user-defined reports. Which would mean a manual update of the definitions.
We have tested successfully a database query approach, as stated below.
A backup of the LSEntry table beforehand is necessary.
In theory, REPORT REREAD command can be used, but best to proceed with a restart to make the changes active in the CAS. Update: REPORT REREAD did not refresh the definitions. After a RELOAD DASHBOARD (Reload report data from database) they were.
Best if the whole operation is done with CAS stopped.
The database command to update all 12.3 reports with Synthetic as dimension filter:
UPDATE [dbo].[CAS].[LSEntry]
SET params = REPLACE(params, '>Synthetic</dimensionFilter', '>Enterprise Synthetic</dimensionFilter')
# optional with the name of a report to test:
and name = ' Test SLM RUM Applications'
Note that this query will not change complex filters like
RUM Browser | RUM sequence transactions | Enterprise Synthetic | Backbone
