how to create alert on low volume
sponnada2
Organizer
hi
How can i create alert for low volume on all applications.acutally we have created one with 50 % benchmark when it having 3 intervals of low volume then its triggering.but we coming across a scenarios like low volume getting cleared off after 10 to 15 min so that we dnt require in that case.SO we should get alert mail when it lasts for long time.
As attached how those colums works excatly
Since NAM 2018 you can use time range and frequency features to adjust your alert to your needs.
