how to create alerts for Heat Chart in DCRUM
sravan_chandupa
Inactive
How to create an alert for transaction operation time in DCRUM.
Jacek_Janowicz
Dynatrace Pro
Dynatrace Pro
Hi Sravankumar
I would suggest you to try to create alert like shown on screenshot below:
You can see Operation selected as monitored dimension and condition created on Operation time metric - in my example value greater than 8s will cause alert triggering. Additionally you can add filters, in my example there is filter on Software service named INT-APP-TA-WebApp-Tomcat. That means, that only operations belonging to this software service will be able to trigger this alert.
Best Regards
Jacek
