how to exclude encypted data and ssl hanshake from monitoring
ngupta13
Participant
how to exclude encypted data and ssl hanshake from monitoring?
3 REPLIES 3
Rafal_Brzezinsk
Dynatrace Helper
Dynatrace Helper
Hello Natasha,
There is ON/OFF functionality to control this on AMD in 17.0.4 – either globally per SSL decode and/or individually per Software Service.
Rafal
Rafal_Brzezinsk
Dynatrace Helper
Dynatrace Helper
Here is the guide:
To turn off reporting of SSL handshakes per software service for the CAS with option below:
(a) Software Services ► Edit Manually ► HTTP options
- *Uncheck*: Inherit from SSL globals
- *Uncheck*: Report SSL handshakes in CAS/ADS data
If we would like to turn off SSL handshakes for HTTP & TDS decodes
(a) Global ► Front-End Monitoring ► Web ► HTTP ► General
(b) Global ► Database Monitoring ► General
ngupta13
Participant
Thank you for the help!!!
