how to filter DB operation from the business unit?
ralkhlailah
Inactive
hello guys,
we have 3 applications using the same DB and the same instance, how I can filter the operations from the business unit for each application, Can I use a prefix or something like that to correlate the relevant operations?
3 REPLIES 3
tore_davidsen
Newcomer
Thank you for your email. I am on vacation until 23rd of August. I will during this time have a delayed processing and response to emails. For urgent matters, you may send me an SMS on my cellphone (004791320972).
ulf_thornander3
Inactive
Hi
You should configure this in Global Setting "Report Database Name"
Hierarchy Levels for Database Monitoring
There are three levels of reporting hierarchy for database monitoring:
  • Operations: Queries or procedure calls
  • Tasks: Query names, query names plus regular expression set on the AMD, or operationtype prefixes.
  • Module: The database name is reported as module.
Specifying the database name using the Module filter is by far the easiest method of accomplishing this.
