how to organize previous built DMI custom reports in 12.2 CAS
kevin_liu1
Guide
i'd like to delete a bunch of old custom DMI reports, rather than going to each one and delete, is there a central location where i can select a whole bunch and delete?
5 REPLIES 5
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
Use :
select * into lsentryBackup2015 from lsentry (for backup)
delete from lsentry where name = 'ReportName' (ReportName = name of your dmi section)
+ CAS restart
JLL
Kevin,
It's not available in the GUI. Only the query from Jean-Louis can help.
Where and how do you apply this query ?
Use SQL Studio logged in as delta or on CAS: http://CAS/sqlreports.
jean_louis_lorm
Dynatrace Pro
Dynatrace Pro
the same with the screen shot 🙂
http: // CAS /sqlreports
1) Backup
2) Delete
3) Restart the CAS
JLL
