integrate dcrum with 2 AppMon machines
erenedo
Organizer
Our customer want to integrate DCRUM 2017 and AppMon 7.1. They have 2 AMDs and 2 AppMon servers.
We've completed the steps commented in
https://www.dynatrace.com/support/doc/dcrum/dc-rum... and
https://www.dynatrace.com/support/doc/dcrum/dc-rum... links. We have done test connections from AppMon and from DCRUM and with products connect fine. In RUM Console we see AppMon devices have been added correctly. But when we verify the integration following this link
https://www.dynatrace.com/support/doc/dcrum/dc-rum... we can`t see the purepaths. We have also created a DMI with columns software service, operations and slow operations and in slow operations creating a drilldown link to access to dynatrace Purepath report but we can´t create this link.
What´s wrong? Is it the same process using 2 AppMon servers.
Thanks in advance.
Elena.
4 REPLIES 4
adam_piotrowicz
Dynatrace Pro
Dynatrace Pro
Elena,
Do you still see this issue?
Hi Adam,
No, we don´t. We got fixing.
Anyway, thanks.
Elena.
If possible please let us know how it was fixed.
Thank you.
Yes, of course.
As one of your colleages told us, we went to CAS/atscon ==>> Command Console, looked for LOG PROFILE ADD and added the Module VADYN. We received an error but when we tried to view purepaths we could see them.
