issue in decoding traffic
swati_bhatnagar
Organizer
Hi ,I am facing a situation where in I have the proper private key for application , I can see proper traffic when doing 'record traffic ' . However traffic is not getting decoded using this key.
I cant see any output when I run command show ssldecr names on AMD .
>$ show ssldecr names
Problem while reading rtm response
Would it affect if the security certificate of application is self signed ? Do we need to import certificate file along with key ?
4 REPLIES 4
fstekelenburg
DynaMight Pro
DynaMight Pro
I think the answer to both last questions is no.
The "Problem while reading rtm response" does not look right. Did you already do a ndstop/ndstart or a reboot? What version are you on? What is the disk space situation?
stop/start had been done and disk space also seems to be fine
DCRUM version is 2017 May .
swati_bhatnagar
Organizer
Can someone help me know if there is any way to check if AMD is actually enabled to decode the data? There is only one SS on this AMD that is using SOAP over HTTPS analyzer , rest all are http/SSL etc.
I wonder if there is anything wrong with the AMD .
