my application doesn't appear in AHS
erenedo
Organizer
I've created an application in APM Model / Business Units.
I defined the applications and their transactions, operations and tiers. But it doesn't appear in Application Health Status dashboard.
What can it wrong?
Thanks in advance.
Elena.
luke_boyling
Dynatrace Pro
Dynatrace Pro
The Application Health Status report only shows active applications within the selected timeframe - i.e. if there's no traffic, it won't appear in the list. For applications that are accessed relatively infrequently, you could try changing the time range to Today, rather than the last hour.
When configuring Business Units, the Business Units screen has a Matching data preview section, which shows if there is matching traffic for the Application/Transaction that you've configured.
You could also determine if there is traffic detected for the underlying software service that is mapped to the application (under the CAS menu -> Explore -> Software services). If so, there might be something wrong with your Business Units configuration.
erenedo
Organizer
Hi Luke,
The application has a lot of traffic.
I solved the problem. The problem was "Make front-end tier" field on webservers tier wasn't check.
Thanks for you answer.
Elena.
