nCipher SSL Card Installation
bernard_theot
Contributor
I try to install nCipher SSL card in AMD 12.4.11 (redHat 7.3).
I can not find the grub.conf file to modify to install the nCipher card.
I found a grub2.cfg, but there is no kernel line to modify.
Would you have an idea for this installation?
Bernard
michal_potacki
Newcomer
On my RHEL7.3 server there is /boot/grub2/grub.cfg but you can skip this.
Michal
