rtm watchdog issue
I have a problem with "rtm watchdog process" that doesn't start with a fresh installation (AMD 12.4.12). At the moment the interface configuration is set only with communication port.
Could depends about the missing capture port or the fault is other ?
Giuseppe
6 REPLIES 6
Erik_Soderquist
Dynatrace Pro
Dynatrace Pro
That is correct, without a correctly configured communications interface and a correctly configured sniffing interface, rtm is expected to fail to start; both are required.
-- Erik
Hello Erik,
thanks for the answer. I was suspecting that, therefore I configured the sniffing port but without active link (wiring still in progress).
Restarting the probe, RTM Watchdog process doesn't start.
Giuseppe
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Can you please share the rtm.log? /usr/adlex/log/rtm.log
Harshal.
hello Harshal, I will try to get it, but is not easy the only way to access on AMD is a secured vpn.
thanks,
Giuseppe
The rtm.log cannot be copied so I have took the relevant ones (I hope they are useful)
L3 2017-04-30 18:13:41.446 0:[main]@main.cpp:451 RTM Probe v. ndw.12.4.12.20 Copyright (C) 1999-2017 Dynatrace LLC.
[Permission] setpriority: Permission denied
L3 2017-04-30 18:13:41.446 0:[main]@common/debugshutdown/debugshutdown.cpp:148 Registered out of memory handler for 'new' operations.
L3 2017-04-30 18:13:41.470 0:[main]@rabase/amdid.cpp:204 00:05.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors (rev 01)
L3 2017-04-30 18:13:41.470 0:[main]@rabase/amdid.cpp:204 7f:14.2 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Error (rev 01)
L3 2017-04-30 18:13:41.470 0:[main]@rabase/amdid.cpp:204 7f:14.3 System peripheral: Intel Corporation Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Error (rev 01)
L3 2017-04-30 18:13:41.474 0:[main]@anlzrext/snc/../../kpa/kpasecfile.cpp:57 failed to open keylist file /usr/adlex/config/keys/keylist
L1 2017-04-30 18:13:41.746 0:[main]@../pmutil/include/mmhash.h:314 WARNING: The file version mismatch, proper version 6d6d0105, read version 6d6d0106
L3 2017-04-30 18:13:41.746 0:[main]@../pmutil/include/mmhash.h:325 WARNING: Cleaning hash table http user name cache content
L2 2017-04-30 18:13:41.753 0:[main]@rabase/appmap.cpp:1479 Error: Unknown analyzer "dns" in "Domain Name Server [U]" definition
L2 2017-04-30 18:13:41.753 0:[main]@rabase/appmap.cpp:1479 Error: Unknown analyzer "kerberosudp" in "Kerberos [U]" definition
L2 2017-04-30 18:13:41.753 0:[main]@rabase/appmap.cpp:1479 Error: Unknown analyzer "rtp" in "RTP" definition
L2 2017-04-30 18:13:41.766 0:[main]@rtmprobe.cpp:591 WARNING! pktmatchconfig rule 'RTP' not used by any Default Software Service
L2 2017-04-30 18:13:41.766 0:[main]@common/precconfig.cpp:501 Invalid server address station: FIXED_ORDER. Skipping...
Thanks in advanced,
Giuseppe
Looks like it got truncated 😞
perhaps opening a ticket for this would be better; I don't see anything in the log fragment that indicates either a shutdown or a crassh
-- Erik
