rum console not working after upgrade 12.4.1
henk_stobbe
DynaMight Pro
DynaMight Pro
After upgrading to 12.4.1 the rum console service is running, but I can not connect to the 4183 port.
In the log I see:
2016-02-05 17:24:02,847 WARN [AbstractLifeCycle] FAILED org.eclipse.jetty.server.Server@1d42a47e: java.io.FileNotFoundException: E:\Program Files\Dynatrace\Common Components\server\configuration\jetty\keystore (The system cannot find the path specified)
I have already tried a reinstall, but that did not help. The environment is not in use, so is there a way do do a clean(er) (re) install?
Cas/CSS/AMD are running perfect
KR Henk
przemyslaw_tafe
Dynatrace Pro
Dynatrace Pro
Henk, please open a support ticket instead to get it resolved.
henk_stobbe
DynaMight Pro
DynaMight Pro
Problem was TLS 1.0 this is not used anymore in RUM Console, turned on TLS 1.1 and problem was solved!
Thanks Tomasz!
