speed dial dashboard reset
david_root
Newcomer
I replaced my speed dial home page in the CAS with another report, how do I get my speed dial back as the landing page? Thanks!
3 REPLIES 3
raffaele_talari
Inactive
Hi David,
have you already tried going back to the speed dial dashboard:
and then set it back as home page from the button on the top-right?
Does it work?
Hope it helps,
Raffaele
david_root
Newcomer
Hello Raffaele,
Thanks for your response. I don't get the action menu when the speed dial dashboard is displayed. Your suggestion works for all the other reports, just not speed dial dashboard for some reason.
Best Regards,
Dave
Hi David,
you are correct - the Action menu is not available for Speed dial and Search screens.
In order to reset you landing page you need to go to "Settings > Security > User rights" and click on the user you wish to change the landing page for.
And then remove everything from the "Home page" field
It will reset your home page to the default settings, i.e., Discovery dashboard for fresh installs and Speed dial dashboard for setups with at least on Software service configured.
You can enforce Speed dial dashboard as your home page by typing
dashboard
in the "Home page" field.
Similarly, if you wish that "Search" becomes your home page, type
search
Sorry for inconvenience, we will enable to easily set those two pages as home page in 12.4.5.
