upgrade Recorder and agent ESM 12.2 to 12.3.6 problem with UserModifiableFunctions.XML
ccarrasco
Inactive
when upgrade the Agent with recorder, you need upgrade the framework and import the file.
but only can find the frameworkupdates.xml
in the folder "Framework Updates" only have frameworkupdates.xml
C:\Program Files (x86)\Compuware\Synthetic Monitoring\Recorder\Framework Updates
where is the UserModifiableFunctions.XML, because this update frame not come with this modulo and when try to star or play a script file, this can run because say something with functions usertakeprintscreen.
yuriy_look
Inactive
@Carlos C.
Hi Carlos,
I agree, this is an inconsistency. Historically in older releases
Framework updates were available on the Agent Manager only. At later
releases UserModifiableFunctions are also available on the Agent in, by
default, C:\Program Files (x86)\Compuware\Synthetic
Monitoring\Recorder\Framework Updates folder. In all releases that
include the Framework, files related to Framework update can be found on the
Agent Manager in C:\Program Files (x86)\Compuware\Synthetic
Just-in-case, if any changes has been made to user modifiable
functions, you will need to merge existing module with what comes with the
FrameWork updated using a code merging tool, like WinMerge. I’d also like to warn you that if you decide
to find the tool on your own, please be aware of many pages in the Internet
that interpret “merge” as concatenation, which, of course, brings wrong
results.
Thank you,
Yuriy
