where does Enterprise synthetic data stores in DB and How to take Enterprise synthetic Database backup
muralikrishna_2
Inactive
ernest_jones
Helper
Hello Murali,
Please clarify your question. Are you just asking where our database files are stored on the database server? Your DBA should be able to find this; you may have modified this during the database install. Do you need the default path? Thanks!
ernest_jones
Helper
The default path is: Program Files (x86)\Microsoft SQL Server\MSSQL12.MSSQLSERVER\MSSQL\DATA
