Calculated Metric Conditions not working for Request attribute
Vikas_g1997
Dynatrace Guide
Dynatrace Guide
Hi Team,
I am attempting to capture a parameter which is SKU 错误 from a request attribute using the conditions below. However, it is not working as expected. I have also created a calculated metric to capture this, but the issue persists.
Could you please assist?
Vikas_g1997_0-1732518201168.pngVikas_g1997_1-1732518228187.pngVikas_g1997_2-1732518255608.png
4 REPLIES 4
paulo_calaxa
Helper
Hi.
First thought out of my head...
I would say it is doing ANDs and can't obey both message filters... solution being to try to filter it with a unique Regex expression, or "equals any of"
KR
Hi @paulo_calaxa ,
Thanks for the suggestion! We have created several calculated metrics, for example: 8000 - 未查询到预订单. I tried using the "equals any of" condition, but it is not working as expected.
But if an AND is the problem, you should try the following:
delete the contains
add the 2nd message filter to the "equals any of condition"
Peter_Youssef
Leader
Hi @Vikas_g1997
As per the attached screenshots, the configurations seem to be fine.
  • First of all, there is Management zone filter applied.
  • Kindly make sure the created metric is added into the management zone using the Dimensional Data option, you will find three options Any / log / Metric proceed with Metric and specify the metric information.
  • Upon saving the configurations, you will see the data presented on the dashboard.
BR,
Peter
